I just found out about cloud compare and downloaded 2.13.2 . But it will not open at all it loads for second but nothing pops up and my task manager wont show it either.
Legion 5 15ARP8
I have a 64-bit system, 32G Ram, AMD Ryzen 7 7735HS with Radeon Graphics.
Windows 11, 23H2
Cloud Compare Wont open
Re: Cloud Compare Wont open
Hum, we've had some issues with ATI cards in the past, but if it's a rather recent one, it should be the problem.
Have you tried to update your graphic card driver just in case?
(on Intel laptops, it's generally possible to switch to the integrated chipset for display, and it's a way to test that the issue comes or not from the graphic card... however in your case, I'm not sure there's such a thing on a Ryzen processor).
I made sure everything was up to date but it continues to not open. I saw it pop up in the "background processes" for half a second but that's as much as I get.
Yes, sadly that's very typical of Qt failing or refusing to start with an 'unsupported' graphic adapter...
