hello,
I'm trying to fill in gaps in a point cloud data. is there a tool i can use in Cloud Compare to do this?
Here is an example of how the hole looks like.
Fill gaps in a point cloud
Re: Fill gaps in a point cloud
I searched for 'fill gaps' on the forum and found: https://www.cloudcompare.org/forum/view ... 593#p26593
You can use same polyline to trim new pointscloud generated by sampling poission mesh
If you need more control of hole (gap) closing , Blender can help a lot
please check attached bin CC file
Meshing by simple Delaunay (best fitting plane) is possible too
(meshing, sampling ,segmenting then merging into original pointscloud)
- 123.png (143.86 KiB) Viewed 4988 times
