We have a problem when importing a .dxf from Autocad to CC.
The mesh representing a theoretical 3D drawing of the tunnel is shifted only at the tunnel exit.
But when we make a polyline/line sections, there is no offset problem.
Can you help us?
Thanks a lot
Import .dxf AutCad to CC
- NOK2.PNG (704.94 KiB) Viewed 1123 times
- NOK.png (110.05 KiB) Viewed 1123 times
- Global.PNG (55.29 KiB) Viewed 1123 times
Re: Import .dxf AutCad to CC
Not sure to fully understand: how was the mesh generated? And with which tool are you extracting the polyline/section?
Also which version are you using?
We have found the solution. It was a drawing problem in autocad, a lack of precision.
Thank you
Thank you
