- handles.png (1000.5 KiB) Viewed 1080 times
Why are my handles this colour?
They just went yellow one day and haven't changed back.
Re: Why are my handles this colour?
Hum, that's very strange.
2 things you can check:
- is the 'custom light' enabled? (you can toggle it with F7)
- has the default light/material been modified? (in the 'Display > Display settings' - you can reset everything t its default)
In any case, it shouldn't cause this change in color, but that may be a bug (so if any on the 2 things above fixed your issue, please report it to us!)
Thanks, Daniel. It's not a big issue, it's just weird.
No, neither of those things helped. There is no shader applied and a I reset the display settings even though I'm pretty sure I didn't change them. Still yellow.
Maybe a driver issue then... Which graphic card do you have?
Sorry for the delay replying. I reinstalled Cloud Compare and now they're back to normal. I have no idea what I did.
I have an RTX3080
I have an RTX3080
Interesting... And I don't see why reinstalling would change that either :D
