[FIXED] Command Line: '-FILTER_SF' does not work
Posted: Wed May 20, 2015 7:14 pm
by vojtek
the following code does not change the input date in any way (despite the fact that it states it does...) - the output file is exactly the same as the input one!!!
cloudcompare -AUTO_SAVE OFF -C_EXPORT_FMT ASC -PREC 8 -EXT PTS -o test.pts -SET_ACTIVE_SF 0 -FILTER_SF -0.0025 +0.0025 -SAVE_CLOUDS[/code]
Is it a BUG or am I doing something wrong?
I do need to process few hundreds of files and I was hoping to do it in a batch mode....
(everything works perfectly in GUI mode)
Please advise
Best regards
Wojtek
Re: Command Line: *** -FILTER_SF *** does not work
Posted: Sat May 23, 2015 8:11 am
Indeed, this is a bug. The cloud was not updated in memory if the AUTO_SAVE feature was disabled.
This is fixed in the latest beta version.
Thanks for the feedback.
Re: [FIXED] Command Line: '-FILTER_SF' does not work
Posted: Wed May 27, 2015 6:24 pm
by vojtek
No problem.
I'm glad I can help at least in this way.
BTW Thanks for the GREAT software!
