import point list
Posted: Wed Jul 01, 2015 5:00 pm
first: Thanks for CloudCompare!
But of course - I have a problem:
I have some unregistrated point clouds from the same objekt and I want to align them with as little efford as possible. But they are very complex and it´s not possible to do this visuably by 4 point-picking (at least without getting mad).
But in the software of the scanner I have for every cloud a list with some points, which should be used as tiepoints.
I can export both pointclouds and tiepoint lists and import them into CloudCompare, but I´m not able to get the information in that the tiepoints have names and are elements of the pointclouds.
To sum it up, is there a possibility to merge the tiepoints with the refered pointcloud without losing the Information: "this exact point is tiepoint 1"? In my next step I would set just the tiepoints visible and align them with pointpicking ( and in my dreams the clouds are fitted magically ;) )
Or is there another better way to solve my problem?
I`m thankful for every hint!
PS: The actual software for my pointcloud is a bit old and I haven´t found such a useful tool like "please merge my tiepoints" or anything else automated. I have only the option to do it manually and this doesn´t work very well.
