Cropping in command line mode
Posted: Thu Dec 08, 2016 11:09 am
I would like to crop a series of point clouds and then compute the cloud to mesh distance from a reference model (mesh). I'm turning this into a batch process, but I get stuck with the cropping. I chose the box dimensions by using the Point Picking Tool in CloudCompare itself and tried to crop it with the Cropping Tool. This works perfectly fine, but when I try the command line operation:
"C:\Program Files\CloudCompare\CloudCompare.exe" -o cloud1.las -CROP {586742:5772727.06:50.59:586748:5772731.14:53.33}
An error appears:
Invalid parameter: box extents (component #1 is not a valid number)
I hope you've got an answer to my question. Batch processing would save a lot of time.
Thanks in advance.
Nina
An error appears:
Thanks in advance.
Nina
