PCV Export
Laurent_B
PCV Export
Post by Laurent_B »
I would like to export the PCV render into a 3D model. Is that possible ? Because when i export in .obj or .ply or whatever, it didn't work. Even if I use " Edit>Scalar field> Convert to RGB.
Thanks in advance
Laurent
Laurent Bitard
Re: PCV Export
You can't use OBJ as it can't save per-vertex colors.
But you could use PLY as it does. However, the software with which you open the PLY file needs to support per-vertex color...
