2.5D vs. 3D
ilovecoffee1125
2.5D vs. 3D
Post by ilovecoffee1125 »
What is the difference between 2.5D from 3D? What is happening to a 3D point cloud that makes it 2.5D?
Re: 2.5D vs. 3D
2.5D means that there's no point that projects on top of other points when the cloud is projected along a specific dimension (generally Z). This generally means that the cloud has been acquired from a quite far distance without changing the orientation too much (e.g. with airborne LIDAR). Or that the shape has only one side (e.g. a mountain seen from the top, etc.).
In this case it's possible to project the cloud along this dimension (e.g. Z) without losing information. This is a requirement for all processes based on rasterization.
davidL
Re: 2.5D vs. 3D
Post by davidL »
Thank you for your answer Daniel!
Would you reccomend using the tool "Compute 2.5 Volume" on a 3d cloud?
Re: 2.5D vs. 3D
Not really! This could give some strange results (you would probably have to split the 3D cloud into two parts at least (like hemispheres of a sphere) to avoid confusion.
