Cross Section in Console problem
Posted: Thu Aug 29, 2019 12:08 am
by Iga
I try to run the cross secrion feature in console but whatever i try to do i get the same message
that console cannot open the xml file. Path is correct, I downloaded the example xml from the site and also created output folder in C:\data\output in order the leave the XML file intact.
Nothing works, console always stops at the xml file.
Tried to run the xml from different locations, same thing happens and everything stops.
Paths are all in latin characters.
Any ideas?
Thank you.
Re: Cross Section in Console problem
Posted: Thu Aug 29, 2019 7:39 pm
What's the message exactly? And which version are you using?
Posted: Thu Aug 29, 2019 11:20 pm
by Iga
Hello, I used v. 2.10.2 and 2.11 alpha.
Please see the image attached.
Posted: Fri Aug 30, 2019 10:12 pm
Why do you have brackets ({}) around the filename?
Posted: Sat Aug 31, 2019 12:23 am
by Iga
: Ο
It was that simple ! Thank you ! :D
It was unclear for me that part.
Thanks again, all ok now.
