Ground segmentation/filtering
Ahmed59
Post by Ahmed59 »
Is there any way to select the ground points from a Lidar point cloud data (PCD)? I need to remove the ground points from a pcd file.
Regards,
Ahmed
Re: Ground segmentation/filtering
You can try to extract them with tools such as the qCSF plugin? (https://www.cloudcompare.org/doc/wiki/i ... F_(plugin))
