Source ID visualisation and modification
GulKhanRa
Post by GulKhanRa »
Hey
I would have the following Questions:
- Is it possible to visualise Source ID inside a single LAS file PER VALUE? I have a LAS file, and I have multiple Source ID inside. I need to visualize each of them in a single color, because scalar field won't make the trick, if I have a value for 10177 and 10178. I need them with discret color, to clearly identify each area.
- Is it possible, to modify Source ID in Cloud Compare in a handy way?
Thank you
Balint
Re: Source ID visualisation and modification
- Yes you could define your own Color scale with specific colors for specific values (see https://www.cloudcompare.org/doc/wiki/i ... es_Manager).
- Another option would be to isolate the points based on their IDs (with Edit > Scalar fields > Filter by value). And then change the colors, or change the associated SF values (with the 'SF Arithmetics' tool).
However if you need to manage that many IDs, it won't be realistic to do it this way :D
