"show 'reference' entities" checkbox is not responsive
Peter140
Post by Peter140 »
I am trying to Align by point pairs picking - it allows me to "show 'to align' entities"(Red) and I can put on 3 points fine, but "show 'reference' entities"(Yellow) checkbox is not responding so I can not select points on 2nd cloud. What am I doing wrong? I am running 111.3.
Thank you very much,
Peter
Re: "show 'reference' entities" checkbox is not responsive
Are you sure you have select only one of the clouds as being 'Aligned'? Because if the two clouds are 'to be aligned', then CC considers that there's no 'reference' cloud (and you have to input the points manually in this case).
zebber
Post by zebber »
I am having the same issue. Trying to Align by point pairs picking - it allows me to "show 'to align' entities"(Red) and I can put on 4 points fine, but "show 'reference' entities"(Yellow) checkbox is not responding so I cannot select points on 2nd cloud. What am I doing wrong? I am running V.2.11.3 (anoia) 64 bit.
Thank you,
Steve
See my answer to your other post.
