procedure for contributing codes to official master branch
plutowing
Post by plutowing »
My colleages and I have developed some codes to work as a plugin in CloudCompare in my organization for in-house use.
Now we want to contribute the codes back to the official master branch for the public to use.
How should I proceed? Need to add test cases scripts before code review?
Pls help.
Thanks,
Pluto
Re: procedure for contributing codes to official master branch
Contributions are always welcome!
Ideally, you should first upload/host your plugin sources on a separate git repository (see for instance https://github.com/hvs-ait/mplane-plugin).
Then you can make a simple pull-request on our master branch, where you add your plugin as a submodule (in 'CloudCompare/plugins/core/Standard' typically). It will let us test it and potentially make some feedback on your plugin repository directly.
plutowing
Post by plutowing »
Thanks for the link and suggested procedures.
Will discuss with my colleagues and proceed soon with git submodule, git fork and pull request.
Thanks,
Pluto
