Hi.
When in commandline running CSF filtering, if syntax outputs both ground and non ground, it will only output one file because it will get overwritten due to naming:
"-CSF -SCENES RELIEF -PROC_SLOPE -CLOTH_RESOLUTION 0.2 -CLASS_THRESHOLD 0.7 -EXPORT_GROUND -EXPORT_OFFGROUND"
"[CSF]
Set scene to relief
Slope processing turned on
Custom cloth resulution set: 0.2
Custom class threshold set: 0.7
Ground will be exported
Off-ground will be exported
[CSF] 99.97% of points classified as ground points
[SAVING]
Extra field 'Illuminance (PCV)' renamed 'Illuminance__(PCV)' to comply to LAS specifications
[I/O] File './08OE2648_PCV_FILTERED_[0_3.las' saved successfully
[SAVING]
Processed finished in 220.88 s."
You can see that despite both are output, due to both having same naming get overwritten by last, the offground, in this case.
So please add -GROUN -OFFGROUND caption in the output file to avoid this, now I can avoid this duplicating the .bat one for the ground other for the offground.
Also, the output file is at same folder as the .bat, where in other commands like PCV the output folder is where the origin file is. You could standarize output dir with like a global variable. But this is not a big issue.
[FIXED ]command line CSF filter only ONE export allowed
Re: command line CSF filter only ONE export allowed
Hum, something else is happening here, as normally the clouds should be suffixed with '_ground_points' and '_offground_points'.
But here, it seems the name is truncated, even before the end of the 'filtered' suffix.
What's the rest of the command line? I'm especially interested in the original cloud name and the various options.
complete command of the .bat
for %%f in (E:\LIDAR_JAPAN\MMS8\MMS\_00_ORIGINAL_PCV\*.las) DO "C:\Program Files\CloudCompare\cloudcompare.exe" -SILENT -O -GLOBAL_SHIFT AUTO %%f -AUTO_SAVE OFF -C_EXPORT_FMT LAS -NO_TIMESTAMP -SET_ACTIVE_SF 9 -FILTER_SF 0 3.1 -CSF -SCENES RELIEF -PROC_SLOPE -CLOTH_RESOLUTION 0.2 -CLASS_THRESHOLD 0.7 -EXPORT_GROUND -EXPORT_OFFGROUND
Original cloud name would be like "08OE2648_PCV", on thing I noticed tho, is that the namig after is "08OE2648_PCV_FILTERED_[0_3" wher I think should be something like "08OE2648_PCV_FILTERED_[0_3.1]_whatever else. I'll try now with even numbers to see if that is the case, will re post.
Hello
You where right, its a naming issue,
with this command line where instead o 0 3.1 the filter rante is 0 3
for %%f in (E:\LIDAR_JAPAN\MMS8\MMS\_00_ORIGINAL_PCV\*.las) DO "C:\Program Files\CloudCompare\cloudcompare.exe" -SILENT -O -GLOBAL_SHIFT AUTO %%f -AUTO_SAVE OFF -C_EXPORT_FMT LAS -NO_TIMESTAMP -SET_ACTIVE_SF 9 -FILTER_SF 0 3 -CSF -SCENES RELIEF -PROC_SLOPE -CLOTH_RESOLUTION 0.2 -CLASS_THRESHOLD 0.7 -EXPORT_GROUND -EXPORT_OFFGROUND
"console print:"
[CSF]
Set scene to relief
[CSF] 99.81% of points classified as ground points
[SAVING]
[I/O] File './08OE2649_FILTERED_[0_3]_ground_points.las' saved successfully
[SAVING]
[I/O] File './08OE2649_FILTERED_[0_3]_offground_points.las' saved successfully
Processed finished in 214.51 s.
"console print:"
[CSF]
Set scene to relief
[SAVING]
[SAVING]
So in the end, the bug is specifically in the CSF plugin command line. I've fixed it in the latest 2.13.alpha version.
I confirm this is fixed, than you so much.
Yes definitely, thanks for the feedback.
And that should be fixed in the latest 2.13.alpha version (from today)
[FIXED ]Re: command line CSF filter only ONE export allowed
I confirm this is fixed.
