To display points based on R,G,B values
Ramiya
Post by Ramiya »
I have a point cloud file with X,Y,Z, R, G, B, Intensity value.
How to display the points based on the R,G,B value in Cloud compare
Regards
Ramiya
Re: To display points based on R,G,B values
Well, with the github version (you'll have to compile it, or wait for the next release ;) you can convert the RGB fields to 3 separate scalar fields. Therefore you'll be able to 'filter' the points based on their associated R, G or B value.
DeepVoid
Post by DeepVoid »
daniel wrote:Well, with the github version (you'll have to compile it, or wait for the next release ;) you can convert the RGB fields to 3 separate scalar fields. Therefore you'll be able to 'filter' the points based on their associated R, G or B value.
Hi, Daniel,
I am new to CloudCompare too, I want to acchieve the same thing as Ramiya does, I am wondering if I can just input the R G B values of each point as three different columns from a ASCII txt file? I want to display every point in its original RGB color.
Best regards
Of course you can load an ASCII point cloud (text file) with X Y Z R G B values on each line. Then you'll be able on import to select the role for each column.
