Produce image from a front view from point cloud
DOUKAS
Post by DOUKAS »
is there a way to produce an image (Tif) from front view? In x an z axis i mean. In order to have a precise photo from thw front of a scanned building.
The point cloud is produces from Pix4d.
Thanks in advance
Re: Produce image from a front view from point cloud
You can either use the 'Display > Render to file' tool (https://www.cloudcompare.org/doc/wiki/i ... er_to_File) or the 'Rasterize' tool if you need a geo-tiff (https://www.cloudcompare.org/doc/wiki/i ... /Rasterize). Make sure to select the right view point, or the right projection dimension, depending on which tool you use.
