Coordinate request 2.14.alpha vs 2.13.2
mariolino
Post by mariolino »
hello Daniel,
please note that with python inside CC 2.13.2 the request for point coordinates via the following code works, whereas in version CC 2.14.alpha for all coordinates only one value is always returned (perhaps the first....)
All the codes I have written now do not work inside CC 2.14.alpha ..... is it possible to do something ?
thanks
Mario
import pycc
import numpy as np
cc = pycc.GetInstance()
entities = cc.getSelectedEntities()
if len(entities) != 1:
    print("\nselect point cloud")
else:
    entity = entities[0]
    if isinstance(entity, pycc.ccPointCloud):
        cloud_coordinates = np.array(entity.points())
        print("\ncoords:")
        for point in cloud_coordinates:
            print(f"({point[0]}, {point[1]}, {point[2]})")
    else:
        print("\nEntity is not a point cloud")
Re: Coordinate request 2.14.alpha vs 2.13.2
Hello, is it with CloudCompy or with the Python plugin within CloudCompare?
These are 2 distinct project from CloudCompare, so it may be more efficient to post this question on their respective github page.
mariolino
Post by mariolino »
the problem is with
CloudCompare Python Plugin by Thomas Montaigu
thanks
mariolino
Post by mariolino »
hi Daniel,
now with 2.14 built 29/9/2024
working correctly
Thnaks
Mariolino
Thanks for the heads up!
