Segmentation or filtering angle beetwen laserbeam and normal
HüttenCrea
Post by HüttenCrea »
I am looking for a tool in CC that allows segmentation of point clouds based on the measured angle between the fixed position camera lidar laser beam and normals.
In practice, if the angle is above a certain limit, the point is automatically deleted.
Thanks in advance.
HüttenCrea
Re: Segmentation or filtering angle beetwen laserbeam and normal
Isn't it the 'Edit > Sensors > Compute Scattering Angles' tool? https://www.cloudcompare.org/doc/wiki/i ... ing_angles
Then you can use 'Edit > Scalar fields > Filter by value'.
HüttenCrea
Thanks Daniel,really great tool.
HüttenCrea
