2.7 with windows 10 dosn't start
I've installed 2.7 version, but it doesn't start. I've made a V 2.6.2 downgrade ant it works properly, like before. ???
Re: 2.7 with windows 10 dosn't start
What's your graphic card? And have you updated the graphic cards driver recently?
CC 2.7 won't work with too old GPUs / drivers.
Same issue here ... meh
Intel® HD Graphics 2000
Same question then :D. Have you updated your drivers recently?
hi, similar issue here too - installed CC 2.7 at work (NVIDIA GeForce GTX 750 Ti) and works fine, but am accessing this computer from remote (NVIDIA GeForce GTX 650 Ti) and CC does not start on the computer at work. Older version of CC works fine... cheers m
Same here. As it was asked about the graphics card - I have NVIDIA NVS 4200M and Intel HD Graphics 3000. Reverted to 32bit (2.6.2) and it started to work again.
@Peter140: why 32 bits and not 64 bits? Otherwise, have you tested the 2.7 version with the NVidia or the Intel card?
here is (as you requested) what the Console reads when I launch CC directly from work:
As mentioned before, the same CC does not start when I try to launch it on the same computer but via remote conection.
cheers
mat
cheers
mat
- CC_console.jpg (52.56 KiB) Viewed 18522 times
Can you run an older version via remote desktop to read the OpenGL version?
