How to add texture information in "ccSphere" class?
Jame
Post by Jame »
Hello! I am a novice, I want to a picture of the aspect ratio of 2:1 to "ccSphere" class structure, according to the sphere of the medial do fake "ccPlane" class, add a "setAsTexture" method, why stick texture are displayed in the sphere of the outside rather than inside, thank you!
Re: How to add texture information in "ccSphere" class?
Can you clarify your question? It's hard to understand...
Jame
Post by Jame »
daniel wrote:Can you clarify your question? It's hard to understand...
I am sorry,it is that I want to add texture in "ccSphere" class,now i add a "setAsTexture" function in "ccSphere" class like "ccPlane" class, and
rewrite the" buildUp" function. The question is that the texture is show abnormal and displayed in the sphere of the outside rather than inside.
The code is:
// Build up.
bool ccSphere::PanoBuildUp()
	//[1]vertices
	unsigned count = (g_iCol+1)*(g_iRow+1);
	//[2]faces
	unsigned faces = g_iCol*g_iRow*2;
	if (!init(count,true,faces,0))
		ccLog::Error("[ccSphere::buildUp] Not enough memory");
		return false;
	//[3] Initialize the ball coordinate matrix
	float SpherePt[g_iCol+1][g_iRow+1][3];
	int step_t = 360/g_iCol;
	int step_f = 180/g_iRow;
	for(int theta=0;theta<=360;theta+=step_t)
		for( int fai=180;fai>=0;fai-=step_f)
			SpherePt[theta/step_t][(180-fai)/step_f][0]=cos((float)theta/180.0*M_PI)*sin((float)fai/180.0*M_PI)*2;
			SpherePt[theta/step_t][(180-fai)/step_f][1]=cos((float)fai/180.0*M_PI)*2;
			SpherePt[theta/step_t][(180-fai)/step_f][2]=sin((float)fai/180.0*M_PI)*sin((float)theta/180.0*M_PI)*2;
	//[4]vertices
		ccPointCloud* verts = vertices();
		assert(verts);
		CCVector3 N,P;
		for(int i=0; i<=g_iCol; ++i)
			for (int j=0; j<=g_iRow; ++j)
				N.x = SpherePt[i][j][0];
				N.y = SpherePt[i][j][1];
				N.z = SpherePt[i][j][2];
				verts->addNorm(N);
				P = N*m_radius;
				verts->addPoint(P);
	//[5]faces
		assert(m_triVertIndexes);
		for (int i=0; i<g_iCol; ++i)
			for (int j=0; j<g_iRow; ++j)
				unsigned A,B,C,D;
				A = i*(g_iRow+1)+j;  //  Lower left corner
				B = i*(g_iRow+1)+j+1; // The upper left corner
				C = (i+1)*(g_iRow+1)+j+1; // Upper right corner
				D = (i+1)*(g_iRow+1)+j; // Bottom right corner
				addTriangle(A, C, B);
				addTriangle(A, D, C);
	notifyGeometryUpdate();
	showNormals(true);
	return true;
// load image texture.
bool ccSphere::setAsTexture(const QImage& image)
 	if (image.isNull())
 		ccLog::Warning("[ccSphere::setAsTexture] Invalid texture image!");
 		return false;
 	//texture coordinates
 	TextureCoordsContainer* texCoords = getTexCoordinatesTable();
 	if (!texCoords)
 		texCoords = new TextureCoordsContainer();
 		if (!texCoords->reserve(g_iCol*g_iRow*4))
 			//not enough memory
 			ccLog::Warning("[ccSphere::setAsTexture] Not enough memory!");
 			delete texCoords;
 			return false;
 		//[2] Texture image coordinate matrix
 		float ImagePt[g_iCol+1][g_iRow+1][2];
 		for(int i=0;i<(g_iCol+1);i++)
 			for(int j=0;j<(g_iRow+1);j++)
 				ImagePt[i][j][0]= (float)i/g_iCol;					// X
 				ImagePt[i][j][1]= (float)j/g_iRow;					// Y
 		//create default texture coordinates
 		float TA[2] = { 0.0f, 0.0f };
 		float TB[2] = { 0.0f, 1.0f };
 		float TC[2] = { 1.0f, 1.0f };
 		float TD[2] = { 1.0f, 0.0f };
 		for (int i=0;i<g_iCol;++i)
 			for (int j=0;j<g_iRow;++j)
 				TA[0]=ImagePt[i][j][0];
 				TA[1]=ImagePt[i][j][1];
 				TB[0]=ImagePt[i][j][0];
 				TB[1]=ImagePt[i][j+1][1];
 				TC[0]=ImagePt[i+1][j+1][0];
 				TC[1]=ImagePt[i+1][j+1][1];
 				TD[0]=ImagePt[i+1][j][0];
 				TD[1]=ImagePt[i][j][1];
 				texCoords->addElement(TA);
				texCoords->addElement(TC);
 				texCoords->addElement(TB);
 				texCoords->addElement(TD);
 		setTexCoordinatesTable(texCoords);
 	if (!hasPerTriangleTexCoordIndexes())
 		if (!reservePerTriangleTexCoordIndexes())
 			//not enough memory
 			ccLog::Warning("[ccPlane::setAsTexture] Not enough memory!");
 			setTexCoordinatesTable(0);
 			removePerTriangleMtlIndexes();
 			return false;
 		//[3] set default texture indexes.
 				unsigned A,B,C,D;
 				A = i*(g_iRow)+j;  //  Lower left corner
 				B = i*(g_iRow)+j+1; // The upper left corner
 				C = (i+1)*(g_iRow)+j+1; // Upper right corner
 				D = (i+1)*(g_iRow)+j; // Bottom right corner
 				addTriangleTexCoordIndexes(A, C, B);
 				addTriangleTexCoordIndexes(A, D, C);
 	if (!hasPerTriangleMtlIndexes())
 		if (!reservePerTriangleMtlIndexes())
 			//not enough memory
 			removePerTriangleTexCoordIndexes();
 			return false;
 		//[3] set default material indexes
  				addTriangleMtlIndex(0);
 	//set material
 	if (!getMaterialSet())
 		setMaterialSet(new ccMaterialSet());
 	ccMaterialSet* materialSet = const_cast<ccMaterialSet*>(getMaterialSet());
 	assert(materialSet);
 	//remove old material (if any)
 	materialSet->clear();
 	//add new material
 		ccMaterial::Shared material(new ccMaterial("texture"));
 		material->setTexture(image,QString(),false);
 		materialSet->addMaterial(material);
 	showMaterials(true);
 	return true;
Jame
Post by Jame »
The aspect ratio of the picture is 2: 1, just like the attach file:"image1.jpg".Thanks very much!
I can't see the image. It would be very helpful ;)
Oh, and can you show us a snapshot of the current result?
Jame
Post by Jame »
daniel wrote:Oh, and can you show us a snapshot of the current result?
Ok! The snapshot of the current result like attach file "snapshot.jpg", I user "ccViewer" to display:
Besides the variable “g_iCol” and "g_iRow" is:
const int g_iCol=90;//Setting the image many times do longitudinal split
const int g_iRow=45;//Setting the image many times do lateral split
Jame
Post by Jame »
daniel wrote:I can't see the image. It would be very helpful ;)
Can't you see the image? I added it by the "Add files" button of "Attachement". ...
Can you see it?
Once you select it, check that the 'status' is a green check symbol. And just to be sure, click on 'place inline' (with the cursor at end of your message for instance).
Jame
Post by Jame »
"image1.jpg":
The snapshot of the result:
"snapshot.jpg"
