Finding the minheight, maxheight, and height range per cell
All about Windows versions
pwan
Post by pwan »
I want to get the height range per cell of a selected point cloud in my plugin. I know the "Tools->Projection->Rasterize" can be used do that, but I don't know how to use the inner function in "ccRasterGrid.h", or "ccRasterizeTool.h". What should I after I get a ccPointCloud *pc ?
Thanks!
pwan
Re: Finding the minheight, maxheight, and height range per cell
Well, the ccRasterizeTool class has not been meant to be used this way, however you can use the 'ccRasterGrid' class:
- init the grid with the right dimensions (ccRasterGrid::init)
- and then project the cloud in the grid (ccRasterGrid::fillWith)
Once done, you can access to the cells of the grid (row by row with the 'rows' member). A cell is valid if its height (h) is not NaN. In this case the other statistics are valid (see the ccRasterCell structure).
