Get attribute from another pointcloud by XYZ
Eilis
Post by Eilis »
I have a pointcloud with valid RGB attributes and a derived pointcloud which has lost its these values after going through further processing. The second pointcloud has fewer points than the original, but the remaining ones should all match a point from the original cloud.
I was wondering if there is a way to fetch the original RGB values to the processed pointcloud in CloudCompare?
Thank you!
Re: Get attribute from another pointcloud by XYZ
Yes, you have to select both entities, and then use 'Edit > Color > Interpolate from another entity'.
See https://www.cloudcompare.org/doc/wiki/i ... her_entity
