Problem building plugins
jonathanbyrn
Post by jonathanbyrn »
hi,
I have downloaded the latest version of cloudcompare from github and I have successfully built it. Unfortunately it does not seem to build the plugins. I can see the plugin code and when I run cmake it says it is auto-adding the plugin folders. I am probably missing something stupid, is there a particular flag I should use?
-- Found X11: /usr/lib/x86_64-linux-gnu/libX11.so
-- Found OpenGL: /usr/lib/x86_64-linux-gnu/libGL.so
-- Auto-add plugin subdir:/home/jonathan/tmp/trunk/plugins/qPCV
-- Auto-add plugin subdir:/home/jonathan/tmp/trunk/plugins/qDummyPlugin
-- Auto-add plugin subdir:/home/jonathan/tmp/trunk/plugins/qPCL
-- Auto-add plugin subdir:/home/jonathan/tmp/trunk/plugins/qEDL
-- Auto-add plugin subdir:/home/jonathan/tmp/trunk/plugins/qHPR
-- Auto-add plugin subdir:/home/jonathan/tmp/trunk/plugins/qSRA
-- Auto-add plugin subdir:/home/jonathan/tmp/trunk/plugins/qRANSAC_SD
-- Auto-add plugin subdir:/home/jonathan/tmp/trunk/plugins/qKinect
-- Auto-add plugin subdir:/home/jonathan/tmp/trunk/plugins/qPoissonRecon
-- Auto-add plugin subdir:/home/jonathan/tmp/trunk/plugins/qBlur
-- Auto-add plugin subdir:/home/jonathan/tmp/trunk/plugins/qSSAO
here are the results for running make:
[  6%] Building CXX object CC/CMakeFiles/CC_CORE_LIB.dir/src/FastMarching.cpp.o
[  6%] Building CXX object CC/CMakeFiles/CC_CORE_LIB.dir/src/NormalDistribution.cpp.o
[  6%] Building CXX object CC/CMakeFiles/CC_CORE_LIB.dir/src/Delaunay2dMesh.cpp.o
[  6%] Building CXX object CC/CMakeFiles/CC_CORE_LIB.dir/src/DgmOctree.cpp.o
[  7%] Building CXX object CC/CMakeFiles/CC_CORE_LIB.dir/src/CloudSamplingTools.cpp.o
[  7%] Building CXX object CC/CMakeFiles/CC_CORE_LIB.dir/src/ChunkedPointCloud.cpp.o
[  7%] Building CXX object CC/CMakeFiles/CC_CORE_LIB.dir/src/LocalModel.cpp.o
[  8%] Building CXX object CC/CMakeFiles/CC_CORE_LIB.dir/src/TrueKdTree.cpp.o
[  8%] Building CXX object CC/CMakeFiles/CC_CORE_LIB.dir/src/ChamferDistanceTransform.cpp.o
[  8%] Building CXX object CC/CMakeFiles/CC_CORE_LIB.dir/src/SimpleCloud.cpp.o
[  8%] Building CXX object CC/CMakeFiles/CC_CORE_LIB.dir/src/DebugProgressCallback.cpp.o
[  9%] Building CXX object CC/CMakeFiles/CC_CORE_LIB.dir/src/WeibullDistribution.cpp.o
[  9%] Building CXX object CC/CMakeFiles/CC_CORE_LIB.dir/src/RegistrationTools.cpp.o
[  9%] Building CXX object CC/CMakeFiles/CC_CORE_LIB.dir/src/PointProjectionTools.cpp.o
[ 10%] Building CXX object CC/CMakeFiles/CC_CORE_LIB.dir/src/ScalarFieldTools.cpp.o
Linking CXX shared library libCC_CORE_LIB.so
[ 10%] Built target CC_CORE_LIB
Scanning dependencies of target GLEW_LIB
[ 10%] Building C object libs/Glew/CMakeFiles/GLEW_LIB.dir/src/glew.c.o
Linking C static library libGLEW_LIB.a
[ 10%] Built target GLEW_LIB
Scanning dependencies of target CC_FBO_LIB
[ 10%] Building CXX object libs/CCFbo/CMakeFiles/CC_FBO_LIB.dir/src/ccBilateralFilter.cpp.o
[ 10%] Building CXX object libs/CCFbo/CMakeFiles/CC_FBO_LIB.dir/src/ccFrameBufferObject.cpp.o
[ 10%] Building CXX object libs/CCFbo/CMakeFiles/CC_FBO_LIB.dir/src/ccFBOUtils.cpp.o
[ 11%] Building CXX object libs/CCFbo/CMakeFiles/CC_FBO_LIB.dir/src/ccShader.cpp.o
Linking CXX static library libCC_FBO_LIB.a
[ 11%] Built target CC_FBO_LIB
[ 11%] Generating moc_ccClipBox.cxx
[ 11%] Generating moc_ccOctree.cxx
[ 12%] Generating moc_ccProgressDialog.cxx
Scanning dependencies of target QCC_DB_LIB
[ 12%] Building CXX object libs/qCC_db/CMakeFiles/QCC_DB_LIB.dir/ccGenericMesh.cpp.o
[ 13%] Building CXX object libs/qCC_db/CMakeFiles/QCC_DB_LIB.dir/ccColorScalesManager.cpp.o
[ 13%] Building CXX object libs/qCC_db/CMakeFiles/QCC_DB_LIB.dir/ccSphere.cpp.o
[ 13%] Building CXX object libs/qCC_db/CMakeFiles/QCC_DB_LIB.dir/ccGBLSensor.cpp.o
[ 13%] Building CXX object libs/qCC_db/CMakeFiles/QCC_DB_LIB.dir/ccCameraSensor.cpp.o
[ 14%] Building CXX object libs/qCC_db/CMakeFiles/QCC_DB_LIB.dir/ccPolyline.cpp.o
[ 14%] Building CXX object libs/qCC_db/CMakeFiles/QCC_DB_LIB.dir/ccDish.cpp.o
[ 14%] Building CXX object libs/qCC_db/CMakeFiles/QCC_DB_LIB.dir/ccFacet.cpp.o
[ 15%] Building CXX object libs/qCC_db/CMakeFiles/QCC_DB_LIB.dir/cc2DLabel.cpp.o
[ 15%] Building CXX object libs/qCC_db/CMakeFiles/QCC_DB_LIB.dir/ccDrawableObject.cpp.o
[ 15%] Building CXX object libs/qCC_db/CMakeFiles/QCC_DB_LIB.dir/cc2DViewportLabel.cpp.o
[ 15%] Building CXX object libs/qCC_db/CMakeFiles/QCC_DB_LIB.dir/ccBBox.cpp.o
[ 16%] Building CXX object libs/qCC_db/CMakeFiles/QCC_DB_LIB.dir/ccCone.cpp.o
[ 16%] Building CXX object libs/qCC_db/CMakeFiles/QCC_DB_LIB.dir/ccSensor.cpp.o
[ 16%] Building CXX object libs/qCC_db/CMakeFiles/QCC_DB_LIB.dir/ccHObject.cpp.o
[ 17%] Building CXX object libs/qCC_db/CMakeFiles/QCC_DB_LIB.dir/ccObject.cpp.o
[ 17%] Building CXX object libs/qCC_db/CMakeFiles/QCC_DB_LIB.dir/ccScalarField.cpp.o
[ 17%] Building CXX object libs/qCC_db/CMakeFiles/QCC_DB_LIB.dir/ccClipBox.cpp.o
[ 17%] Building CXX object libs/qCC_db/CMakeFiles/QCC_DB_LIB.dir/ccSubMesh.cpp.o
[ 18%] Building CXX object libs/qCC_db/CMakeFiles/QCC_DB_LIB.dir/ccGenericPointCloud.cpp.o
[ 18%] Building CXX object libs/qCC_db/CMakeFiles/QCC_DB_LIB.dir/ccTorus.cpp.o
[ 18%] Building CXX object libs/qCC_db/CMakeFiles/QCC_DB_LIB.dir/ccCalibratedImage.cpp.o
[ 19%] Building CXX object libs/qCC_db/CMakeFiles/QCC_DB_LIB.dir/ccIndexedTransformationBuffer.cpp.o
[ 19%] Building CXX object libs/qCC_db/CMakeFiles/QCC_DB_LIB.dir/ccOctree.cpp.o
[ 19%] Building CXX object libs/qCC_db/CMakeFiles/QCC_DB_LIB.dir/cc2DViewportObject.cpp.o
[ 19%] Building CXX object libs/qCC_db/CMakeFiles/QCC_DB_LIB.dir/ccMaterial.cpp.o
[ 20%] Building CXX object libs/qCC_db/CMakeFiles/QCC_DB_LIB.dir/ccLog.cpp.o
[ 20%] Building CXX object libs/qCC_db/CMakeFiles/QCC_DB_LIB.dir/ccGLMatrix.cpp.o
[ 20%] Building CXX object libs/qCC_db/CMakeFiles/QCC_DB_LIB.dir/ccMaterialSet.cpp.o
[ 21%] Building CXX object libs/qCC_db/CMakeFiles/QCC_DB_LIB.dir/ccGenericGLDisplay.cpp.o
[ 21%] Building CXX object libs/qCC_db/CMakeFiles/QCC_DB_LIB.dir/ccGLUtils.cpp.o
[ 21%] Building CXX object libs/qCC_db/CMakeFiles/QCC_DB_LIB.dir/ccNormalVectors.cpp.o
[ 21%] Building CXX object libs/qCC_db/CMakeFiles/QCC_DB_LIB.dir/ccMesh.cpp.o
[ 22%] Building CXX object libs/qCC_db/CMakeFiles/QCC_DB_LIB.dir/ccHObjectCaster.cpp.o
[ 22%] Building CXX object libs/qCC_db/CMakeFiles/QCC_DB_LIB.dir/ccProgressDialog.cpp.o
[ 22%] Building CXX object libs/qCC_db/CMakeFiles/QCC_DB_LIB.dir/ccMeshGroup.cpp.o
[ 23%] Building CXX object libs/qCC_db/CMakeFiles/QCC_DB_LIB.dir/ccPlane.cpp.o
[ 23%] Building CXX object libs/qCC_db/CMakeFiles/QCC_DB_LIB.dir/ccCylinder.cpp.o
[ 23%] Building CXX object libs/qCC_db/CMakeFiles/QCC_DB_LIB.dir/ccTimer.cpp.o
[ 23%] Building CXX object libs/qCC_db/CMakeFiles/QCC_DB_LIB.dir/ccPointCloud.cpp.o
[ 24%] Building CXX object libs/qCC_db/CMakeFiles/QCC_DB_LIB.dir/ccBox.cpp.o
[ 24%] Building CXX object libs/qCC_db/CMakeFiles/QCC_DB_LIB.dir/ccGenericPrimitive.cpp.o
[ 24%] Building CXX object libs/qCC_db/CMakeFiles/QCC_DB_LIB.dir/ccColorScale.cpp.o
[ 25%] Building CXX object libs/qCC_db/CMakeFiles/QCC_DB_LIB.dir/ccExtru.cpp.o
[ 25%] Building CXX object libs/qCC_db/CMakeFiles/QCC_DB_LIB.dir/ccIndexedTransformation.cpp.o
[ 25%] Building CXX object libs/qCC_db/CMakeFiles/QCC_DB_LIB.dir/ccKdTree.cpp.o
[ 25%] Building CXX object libs/qCC_db/CMakeFiles/QCC_DB_LIB.dir/ccImage.cpp.o
[ 26%] Building CXX object libs/qCC_db/CMakeFiles/QCC_DB_LIB.dir/moc_ccOctree.cxx.o
[ 26%] Building CXX object libs/qCC_db/CMakeFiles/QCC_DB_LIB.dir/moc_ccProgressDialog.cxx.o
[ 26%] Building CXX object libs/qCC_db/CMakeFiles/QCC_DB_LIB.dir/moc_ccClipBox.cxx.o
Linking CXX shared library libQCC_DB_LIB.so
[ 26%] Built target QCC_DB_LIB
[ 26%] Generating ui_openLASFileDlg.h
[ 26%] Generating moc_PlyOpenDlg.cxx
[ 26%] Generating moc_BundlerImportDlg.cxx
[ 27%] Generating moc_AsciiOpenDlg.cxx
[ 27%] Generating moc_AsciiSaveDlg.cxx
[ 27%] Generating moc_ccShiftAndScaleCloudDlg.cxx
[ 27%] Generating ui_openBundlerFileDlg.h
[ 28%] Generating ui_saveAsciiFileDlg.h
[ 28%] Generating ui_shiftAndScaleCloudDlg.h
[ 28%] Generating ui_openAsciiFileDlg.h
[ 29%] Generating ui_openPlyFileDlg.h
Scanning dependencies of target QCC_IO_LIB
[ 29%] Building CXX object libs/qCC_io/CMakeFiles/QCC_IO_LIB.dir/STLFilter.cpp.o
[ 29%] Building CXX object libs/qCC_io/CMakeFiles/QCC_IO_LIB.dir/LASOpenDlg.cpp.o
[ 30%] Building CXX object libs/qCC_io/CMakeFiles/QCC_IO_LIB.dir/ccShiftAndScaleCloudDlg.cpp.o
[ 30%] Building CXX object libs/qCC_io/CMakeFiles/QCC_IO_LIB.dir/SoiFilter.cpp.o
[ 30%] Building CXX object libs/qCC_io/CMakeFiles/QCC_IO_LIB.dir/BinFilter.cpp.o
[ 31%] Building CXX object libs/qCC_io/CMakeFiles/QCC_IO_LIB.dir/AsciiFilter.cpp.o
[ 31%] Building CXX object libs/qCC_io/CMakeFiles/QCC_IO_LIB.dir/AsciiSaveDlg.cpp.o
[ 31%] Building CXX object libs/qCC_io/CMakeFiles/QCC_IO_LIB.dir/E57Filter.cpp.o
[ 31%] Building CXX object libs/qCC_io/CMakeFiles/QCC_IO_LIB.dir/ObjFilter.cpp.o
[ 32%] Building CXX object libs/qCC_io/CMakeFiles/QCC_IO_LIB.dir/PlyFilter.cpp.o
[ 32%] Building CXX object libs/qCC_io/CMakeFiles/QCC_IO_LIB.dir/DxfFilter.cpp.o
[ 32%] Building CXX object libs/qCC_io/CMakeFiles/QCC_IO_LIB.dir/PNFilter.cpp.o
[ 33%] Building CXX object libs/qCC_io/CMakeFiles/QCC_IO_LIB.dir/VTKFilter.cpp.o
[ 33%] Building CXX object libs/qCC_io/CMakeFiles/QCC_IO_LIB.dir/FBXFilter.cpp.o
[ 33%] Building CXX object libs/qCC_io/CMakeFiles/QCC_IO_LIB.dir/PVFilter.cpp.o
[ 33%] Building CXX object libs/qCC_io/CMakeFiles/QCC_IO_LIB.dir/LASFilter.cpp.o
[ 34%] Building CXX object libs/qCC_io/CMakeFiles/QCC_IO_LIB.dir/IcmFilter.cpp.o
[ 34%] Building CXX object libs/qCC_io/CMakeFiles/QCC_IO_LIB.dir/FileIOFilter.cpp.o
[ 34%] Building CXX object libs/qCC_io/CMakeFiles/QCC_IO_LIB.dir/PTXFilter.cpp.o
[ 35%] Building CXX object libs/qCC_io/CMakeFiles/QCC_IO_LIB.dir/BundlerFilter.cpp.o
[ 35%] Building CXX object libs/qCC_io/CMakeFiles/QCC_IO_LIB.dir/AsciiOpenDlg.cpp.o
[ 35%] Building CXX object libs/qCC_io/CMakeFiles/QCC_IO_LIB.dir/DepthMapFileFilter.cpp.o
[ 35%] Building CXX object libs/qCC_io/CMakeFiles/QCC_IO_LIB.dir/ccCoordinatesShiftManager.cpp.o
[ 36%] Building CXX object libs/qCC_io/CMakeFiles/QCC_IO_LIB.dir/X3DXIOTNodeHandler.cpp.o
[ 36%] Building CXX object libs/qCC_io/CMakeFiles/QCC_IO_LIB.dir/PCDFilter.cpp.o
[ 36%] Building CXX object libs/qCC_io/CMakeFiles/QCC_IO_LIB.dir/MAFilter.cpp.o
[ 37%] Building CXX object libs/qCC_io/CMakeFiles/QCC_IO_LIB.dir/BundlerImportDlg.cpp.o
[ 37%] Building CXX object libs/qCC_io/CMakeFiles/QCC_IO_LIB.dir/PlyOpenDlg.cpp.o
[ 37%] Building CXX object libs/qCC_io/CMakeFiles/QCC_IO_LIB.dir/OFFFilter.cpp.o
[ 37%] Building CXX object libs/qCC_io/CMakeFiles/QCC_IO_LIB.dir/PovFilter.cpp.o
[ 38%] Building CXX object libs/qCC_io/CMakeFiles/QCC_IO_LIB.dir/X3DFilter.cpp.o
[ 38%] Building CXX object libs/qCC_io/CMakeFiles/QCC_IO_LIB.dir/InputMemoryFile.cpp.o
[ 38%] Building CXX object libs/qCC_io/CMakeFiles/QCC_IO_LIB.dir/RasterGridFilter.cpp.o
[ 39%] Building C object libs/qCC_io/CMakeFiles/QCC_IO_LIB.dir/rply.c.o
[ 39%] Building CXX object libs/qCC_io/CMakeFiles/QCC_IO_LIB.dir/moc_PlyOpenDlg.cxx.o
[ 39%] Building CXX object libs/qCC_io/CMakeFiles/QCC_IO_LIB.dir/moc_BundlerImportDlg.cxx.o
[ 39%] Building CXX object libs/qCC_io/CMakeFiles/QCC_IO_LIB.dir/moc_AsciiOpenDlg.cxx.o
[ 40%] Building CXX object libs/qCC_io/CMakeFiles/QCC_IO_LIB.dir/moc_AsciiSaveDlg.cxx.o
[ 40%] Building CXX object libs/qCC_io/CMakeFiles/QCC_IO_LIB.dir/moc_ccShiftAndScaleCloudDlg.cxx.o
Linking CXX static library libQCC_IO_LIB.a
[ 40%] Built target QCC_IO_LIB
[ 41%] Generating moc_ccGLWindow.cxx
Scanning dependencies of target QCC_GL_LIB
[ 41%] Building CXX object libs/qCC_glWindow/CMakeFiles/QCC_GL_LIB.dir/ccRenderingTools.cpp.o
[ 41%] Building CXX object libs/qCC_glWindow/CMakeFiles/QCC_GL_LIB.dir/ccGLWindow.cpp.o
[ 41%] Building CXX object libs/qCC_glWindow/CMakeFiles/QCC_GL_LIB.dir/ccGuiParameters.cpp.o
[ 42%] Building CXX object libs/qCC_glWindow/CMakeFiles/QCC_GL_LIB.dir/moc_ccGLWindow.cxx.o
Linking CXX static library libQCC_GL_LIB.a
[ 42%] Built target QCC_GL_LIB
[ 42%] Generating qrc_icones.cxx
[ 42%] Generating moc_ccHistogramWindow.cxx
[ 42%] Generating moc_ccSubsamplingDlg.cxx
[ 43%] Generating moc_ccUnrollDlg.cxx
[ 43%] Generating moc_ccNormalComputationDlg.cxx
[ 43%] Generating moc_ccColorScaleEditorWidget.cxx
[ 43%] Generating moc_ccBoundingBoxEditorDlg.cxx
[ 44%] Generating moc_ccClippingBoxTool.cxx
[ 44%] Generating moc_ccAdjustZoomDlg.cxx
[ 44%] Generating moc_ccApplyTransformationDlg.cxx
[ 45%] Generating moc_ccPointPickingGenericInterface.cxx
[ 45%] Generating moc_ccGraphicalTransformationTool.cxx
[ 45%] Generating moc_ccColorGradientDlg.cxx
[ 45%] Generating moc_ccCameraParamEditDlg.cxx
[ 46%] Generating moc_ccMouse3DContextMenu.cxx
[ 46%] Generating moc_mainwindow.cxx
[ 46%] Generating moc_ccRegistrationDlg.cxx
[ 47%] Generating moc_ccRenderToFileDlg.cxx
[ 47%] Generating moc_ccPointPropertiesDlg.cxx
[ 47%] Generating moc_ccOrderChoiceDlg.cxx
[ 47%] Generating moc_ccPrimitiveFactoryDlg.cxx
[ 48%] Generating moc_ccGraphicalSegmentationTool.cxx
[ 48%] Generating moc_ccHeightGridGenerationDlg.cxx
[ 48%] Generating moc_ccPluginDlg.cxx
[ 49%] Generating moc_ccClippingBoxRepeatDlg.cxx
[ 49%] Generating moc_ccDisplayOptionsDlg.cxx
[ 49%] Generating moc_ccPointPairRegistrationDlg.cxx
[ 49%] Generating moc_ccOverlayDialog.cxx
[ 50%] Generating moc_ccColorScaleSelector.cxx
[ 50%] Generating moc_ccColorScaleEditorDlg.cxx
[ 50%] Generating moc_ccConsole.cxx
[ 51%] Generating moc_ccPointListPickingDlg.cxx
[ 51%] Generating moc_ccComparisonDlg.cxx
[ 51%] Generating moc_ccAlignDlg.cxx
[ 51%] Generating db_tree/moc_ccDBRoot.cxx
[ 52%] Generating db_tree/moc_sfEditDlg.cxx
[ 52%] Generating db_tree/moc_ccPropertiesTreeDelegate.cxx
[ 52%] Generating __/libs/qxt/moc_qxtspanslider.cxx
[ 53%] Generating __/libs/qxt/moc_qxtspanslider_p.cxx
[ 53%] Generating ui_normalComputationDlg.h
[ 53%] Generating ui_scalarFieldFromColorDlg.h
[ 53%] Generating ui_curvatureDlg.h
[ 54%] Generating ui_sensorComputeDistancesDlg.h
[ 54%] Generating ui_unrollDlg.h
[ 54%] Generating ui_sensorComputeScatteringAnglesDlg.h
[ 55%] Generating ui_aboutDlg.h
[ 55%] Generating ui_colorGradientDlg.h
[ 55%] Generating ui_mainWindow.h
[ 55%] Generating ui_askOneIntValueDlg.h
[ 56%] Generating ui_adjustZoomDlg.h
[ 56%] Generating ui_askThreeDoubleValuesDlg.h
[ 56%] Generating ui_askOneDoubleValueDlg.h
[ 57%] Generating ui_sfComparisonDlg.h
[ 57%] Generating ui_cameraParamDlg.h
[ 57%] Generating ui_graphicalSegmentationDlg.h
[ 57%] Generating ui_sensorProjectDlg.h
[ 58%] Generating ui_heightGridGenerationDlg.h
[ 58%] Generating ui_statisticalTestDlg.h
[ 58%] Generating ui_registrationDlg.h
[ 59%] Generating ui_primitiveFactoryDlg.h
[ 59%] Generating ui_applyTransformationDlg.h
[ 59%] Generating ui_pointPropertiesDlg.h
[ 59%] Generating ui_comparisonDlg.h
[ 60%] Generating ui_rasterExportOptionsDlg.h
[ 60%] Generating ui_colorScaleEditorDlg.h
[ 60%] Generating ui_commandLineDlg.h
[ 61%] Generating ui_alignDlg.h
[ 61%] Generating ui_graphicalTransformationDlg.h
[ 61%] Generating ui_pointListPickingDlg.h
[ 61%] Generating ui_boundingBoxEditorDlg.h
[ 62%] Generating ui_pointPairRegistrationDlg.h
[ 62%] Generating ui_computeOctreeDlg.h
[ 62%] Generating ui_ptsSamplingDlg.h
[ 63%] Generating ui_clippingBoxDlg.h
[ 63%] Generating ui_renderToFileDialog.h
[ 63%] Generating ui_askTwoDoubleValuesDlg.h
[ 63%] Generating ui_subsamplingDlg.h
[ 64%] Generating ui_askOneStringDlg.h
[ 64%] Generating ui_pickOneElementDlg.h
[ 64%] Generating ui_exportCoordToSFDlg.h
[ 65%] Generating ui_roleChoiceDlg.h
[ 65%] Generating ui_sfEditDlg.h
[ 65%] Generating ui_clippingBoxRepeatDlg.h
[ 65%] Generating ui_labelingDlg.h
[ 66%] Generating ui_displayOptionsDlg.h
Scanning dependencies of target CloudCompare
[ 66%] Building CXX object qCC/CMakeFiles/CloudCompare.dir/ccColorScaleEditorDlg.cpp.o
[ 67%] Building CXX object qCC/CMakeFiles/CloudCompare.dir/ccPickOneElementDlg.cpp.o
[ 67%] Building CXX object qCC/CMakeFiles/CloudCompare.dir/ccGraphicalTransformationTool.cpp.o
[ 67%] Building CXX object qCC/CMakeFiles/CloudCompare.dir/ccAdjustZoomDlg.cpp.o
[ 67%] Building CXX object qCC/CMakeFiles/CloudCompare.dir/ccOrderChoiceDlg.cpp.o
[ 68%] Building CXX object qCC/CMakeFiles/CloudCompare.dir/ccHeightGridGeneration.cpp.o
[ 68%] Building CXX object qCC/CMakeFiles/CloudCompare.dir/ccPtsSamplingDlg.cpp.o
[ 68%] Building CXX object qCC/CMakeFiles/CloudCompare.dir/ccAskTwoDoubleValuesDlg.cpp.o
[ 69%] Building CXX object qCC/CMakeFiles/CloudCompare.dir/ccComparisonDlg.cpp.o
[ 69%] Building CXX object qCC/CMakeFiles/CloudCompare.dir/ccNormalComputationDlg.cpp.o
[ 69%] Building CXX object qCC/CMakeFiles/CloudCompare.dir/ccSensorComputeDistancesDlg.cpp.o
[ 69%] Building CXX object qCC/CMakeFiles/CloudCompare.dir/ccPrimitiveFactoryDlg.cpp.o
[ 70%] Building CXX object qCC/CMakeFiles/CloudCompare.dir/ccScalarFieldFromColorDlg.cpp.o
[ 70%] Building CXX object qCC/CMakeFiles/CloudCompare.dir/ccCommandLineParser.cpp.o
[ 70%] Building CXX object qCC/CMakeFiles/CloudCompare.dir/ccPointListPickingDlg.cpp.o
[ 71%] Building CXX object qCC/CMakeFiles/CloudCompare.dir/ccClippingBoxTool.cpp.o
[ 71%] Building CXX object qCC/CMakeFiles/CloudCompare.dir/ccColorGradientDlg.cpp.o
[ 71%] Building CXX object qCC/CMakeFiles/CloudCompare.dir/ccPointPairRegistrationDlg.cpp.o
[ 71%] Building CXX object qCC/CMakeFiles/CloudCompare.dir/ccComputeOctreeDlg.cpp.o
[ 72%] Building CXX object qCC/CMakeFiles/CloudCompare.dir/ccRegistrationTools.cpp.o
[ 72%] Building CXX object qCC/CMakeFiles/CloudCompare.dir/ccGraphicalSegmentationTool.cpp.o
[ 72%] Building CXX object qCC/CMakeFiles/CloudCompare.dir/ccMinimumSpanningTreeForNormsDirection.cpp.o
[ 73%] Building CXX object qCC/CMakeFiles/CloudCompare.dir/ccSubsamplingDlg.cpp.o
[ 73%] Building CXX object qCC/CMakeFiles/CloudCompare.dir/ccPointPropertiesDlg.cpp.o
[ 73%] Building CXX object qCC/CMakeFiles/CloudCompare.dir/ccCommon.cpp.o
[ 73%] Building CXX object qCC/CMakeFiles/CloudCompare.dir/ccAskThreeDoubleValuesDlg.cpp.o
[ 74%] Building CXX object qCC/CMakeFiles/CloudCompare.dir/ccApplyTransformationDlg.cpp.o
[ 74%] Building CXX object qCC/CMakeFiles/CloudCompare.dir/main.cpp.o
[ 74%] Building CXX object qCC/CMakeFiles/CloudCompare.dir/ccHistogramWindow.cpp.o
[ 75%] Building CXX object qCC/CMakeFiles/CloudCompare.dir/ccExportCoordToSFDlg.cpp.o
[ 75%] Building CXX object qCC/CMakeFiles/CloudCompare.dir/ccUnrollDlg.cpp.o
[ 75%] Building CXX object qCC/CMakeFiles/CloudCompare.dir/ccDisplayOptionsDlg.cpp.o
[ 75%] Building CXX object qCC/CMakeFiles/CloudCompare.dir/ccCameraParamEditDlg.cpp.o
[ 76%] Building CXX object qCC/CMakeFiles/CloudCompare.dir/ccLabelingDlg.cpp.o
[ 76%] Building CXX object qCC/CMakeFiles/CloudCompare.dir/ccFastMarchingForNormsDirection.cpp.o
[ 76%] Building CXX object qCC/CMakeFiles/CloudCompare.dir/ccScalarFieldArithmeticDlg.cpp.o
[ 77%] Building CXX object qCC/CMakeFiles/CloudCompare.dir/ccOverlayDialog.cpp.o
[ 77%] Building CXX object qCC/CMakeFiles/CloudCompare.dir/ccSensorProjectionDlg.cpp.o
[ 77%] Building CXX object qCC/CMakeFiles/CloudCompare.dir/ccPluginDlg.cpp.o
[ 77%] Building CXX object qCC/CMakeFiles/CloudCompare.dir/ccColorScaleSelector.cpp.o
[ 78%] Building CXX object qCC/CMakeFiles/CloudCompare.dir/ccConsole.cpp.o
[ 78%] Building CXX object qCC/CMakeFiles/CloudCompare.dir/ccRenderToFileDlg.cpp.o
[ 78%] Building CXX object qCC/CMakeFiles/CloudCompare.dir/ccHeightGridGenerationDlg.cpp.o
[ 79%] Building CXX object qCC/CMakeFiles/CloudCompare.dir/mainwindow.cpp.o
[ 79%] Building CXX object qCC/CMakeFiles/CloudCompare.dir/ccInnerRect2DFinder.cpp.o
[ 79%] Building CXX object qCC/CMakeFiles/CloudCompare.dir/ccCurvatureDlg.cpp.o
[ 79%] Building CXX object qCC/CMakeFiles/CloudCompare.dir/ccSensorComputeScatteringAnglesDlg.cpp.o
[ 80%] Building CXX object qCC/CMakeFiles/CloudCompare.dir/ccMouse3DContextMenu.cpp.o
[ 80%] Building CXX object qCC/CMakeFiles/CloudCompare.dir/ccColorScaleEditorWidget.cpp.o
[ 80%] Building CXX object qCC/CMakeFiles/CloudCompare.dir/ccRegistrationDlg.cpp.o
[ 81%] Building CXX object qCC/CMakeFiles/CloudCompare.dir/ccClippingBoxRepeatDlg.cpp.o
[ 81%] Building CXX object qCC/CMakeFiles/CloudCompare.dir/ccPointPickingGenericInterface.cpp.o
[ 81%] Building CXX object qCC/CMakeFiles/CloudCompare.dir/ccStatisticalTestDlg.cpp.o
[ 81%] Building CXX object qCC/CMakeFiles/CloudCompare.dir/ccBoundingBoxEditorDlg.cpp.o
[ 82%] Building CXX object qCC/CMakeFiles/CloudCompare.dir/ccAlignDlg.cpp.o
[ 82%] Building CXX object qCC/CMakeFiles/CloudCompare.dir/db_tree/ccDBRoot.cpp.o
[ 82%] Building CXX object qCC/CMakeFiles/CloudCompare.dir/db_tree/sfEditDlg.cpp.o
[ 82%] Building CXX object qCC/CMakeFiles/CloudCompare.dir/db_tree/ccPropertiesTreeDelegate.cpp.o
[ 83%] Building CXX object qCC/CMakeFiles/CloudCompare.dir/__/libs/qxt/qxtspanslider.cpp.o
[ 83%] Building CXX object qCC/CMakeFiles/CloudCompare.dir/moc_ccHistogramWindow.cxx.o
[ 83%] Building CXX object qCC/CMakeFiles/CloudCompare.dir/moc_ccSubsamplingDlg.cxx.o
[ 84%] Building CXX object qCC/CMakeFiles/CloudCompare.dir/moc_ccUnrollDlg.cxx.o
[ 84%] Building CXX object qCC/CMakeFiles/CloudCompare.dir/moc_ccNormalComputationDlg.cxx.o
[ 84%] Building CXX object qCC/CMakeFiles/CloudCompare.dir/moc_ccColorScaleEditorWidget.cxx.o
[ 84%] Building CXX object qCC/CMakeFiles/CloudCompare.dir/moc_ccBoundingBoxEditorDlg.cxx.o
[ 85%] Building CXX object qCC/CMakeFiles/CloudCompare.dir/moc_ccClippingBoxTool.cxx.o
[ 85%] Building CXX object qCC/CMakeFiles/CloudCompare.dir/moc_ccAdjustZoomDlg.cxx.o
[ 85%] Building CXX object qCC/CMakeFiles/CloudCompare.dir/moc_ccApplyTransformationDlg.cxx.o
[ 86%] Building CXX object qCC/CMakeFiles/CloudCompare.dir/moc_ccPointPickingGenericInterface.cxx.o
[ 86%] Building CXX object qCC/CMakeFiles/CloudCompare.dir/moc_ccGraphicalTransformationTool.cxx.o
[ 86%] Building CXX object qCC/CMakeFiles/CloudCompare.dir/moc_ccColorGradientDlg.cxx.o
[ 86%] Building CXX object qCC/CMakeFiles/CloudCompare.dir/moc_ccCameraParamEditDlg.cxx.o
[ 87%] Building CXX object qCC/CMakeFiles/CloudCompare.dir/moc_ccMouse3DContextMenu.cxx.o
[ 87%] Building CXX object qCC/CMakeFiles/CloudCompare.dir/moc_mainwindow.cxx.o
[ 87%] Building CXX object qCC/CMakeFiles/CloudCompare.dir/moc_ccRegistrationDlg.cxx.o
[ 88%] Building CXX object qCC/CMakeFiles/CloudCompare.dir/moc_ccRenderToFileDlg.cxx.o
[ 88%] Building CXX object qCC/CMakeFiles/CloudCompare.dir/moc_ccPointPropertiesDlg.cxx.o
[ 88%] Building CXX object qCC/CMakeFiles/CloudCompare.dir/moc_ccOrderChoiceDlg.cxx.o
[ 88%] Building CXX object qCC/CMakeFiles/CloudCompare.dir/moc_ccPrimitiveFactoryDlg.cxx.o
[ 89%] Building CXX object qCC/CMakeFiles/CloudCompare.dir/moc_ccGraphicalSegmentationTool.cxx.o
[ 89%] Building CXX object qCC/CMakeFiles/CloudCompare.dir/moc_ccHeightGridGenerationDlg.cxx.o
[ 89%] Building CXX object qCC/CMakeFiles/CloudCompare.dir/moc_ccPluginDlg.cxx.o
[ 90%] Building CXX object qCC/CMakeFiles/CloudCompare.dir/moc_ccClippingBoxRepeatDlg.cxx.o
[ 90%] Building CXX object qCC/CMakeFiles/CloudCompare.dir/moc_ccDisplayOptionsDlg.cxx.o
[ 90%] Building CXX object qCC/CMakeFiles/CloudCompare.dir/moc_ccPointPairRegistrationDlg.cxx.o
[ 90%] Building CXX object qCC/CMakeFiles/CloudCompare.dir/moc_ccOverlayDialog.cxx.o
[ 91%] Building CXX object qCC/CMakeFiles/CloudCompare.dir/moc_ccColorScaleSelector.cxx.o
[ 91%] Building CXX object qCC/CMakeFiles/CloudCompare.dir/moc_ccColorScaleEditorDlg.cxx.o
[ 91%] Building CXX object qCC/CMakeFiles/CloudCompare.dir/moc_ccConsole.cxx.o
[ 92%] Building CXX object qCC/CMakeFiles/CloudCompare.dir/moc_ccPointListPickingDlg.cxx.o
[ 92%] Building CXX object qCC/CMakeFiles/CloudCompare.dir/moc_ccComparisonDlg.cxx.o
[ 92%] Building CXX object qCC/CMakeFiles/CloudCompare.dir/moc_ccAlignDlg.cxx.o
[ 92%] Building CXX object qCC/CMakeFiles/CloudCompare.dir/db_tree/moc_ccDBRoot.cxx.o
[ 93%] Building CXX object qCC/CMakeFiles/CloudCompare.dir/db_tree/moc_sfEditDlg.cxx.o
[ 93%] Building CXX object qCC/CMakeFiles/CloudCompare.dir/db_tree/moc_ccPropertiesTreeDelegate.cxx.o
[ 93%] Building CXX object qCC/CMakeFiles/CloudCompare.dir/__/libs/qxt/moc_qxtspanslider.cxx.o
[ 94%] Building CXX object qCC/CMakeFiles/CloudCompare.dir/__/libs/qxt/moc_qxtspanslider_p.cxx.o
[ 94%] Building CXX object qCC/CMakeFiles/CloudCompare.dir/qrc_icones.cxx.o
Linking CXX executable CloudCompare
[ 94%] Built target CloudCompare
[ 94%] Generating qrc_icones.cxx
[ 94%] Generating moc_ccviewer.cxx
[ 95%] Generating __/qCC/moc_ccOverlayDialog.cxx
[ 95%] Generating __/qCC/moc_ccCameraParamEditDlg.cxx
[ 95%] Generating __/qCC/moc_ccDisplayOptionsDlg.cxx
[ 95%] Generating __/qCC/moc_ccMouse3DContextMenu.cxx
[ 96%] Generating ui_ccviewerAbout.h
[ 96%] Generating ui_ccviewer.h
[ 96%] Generating ui_cameraParamDlg.h
[ 97%] Generating ui_displayOptionsDlg.h
Scanning dependencies of target ccViewer
[ 97%] Building CXX object ccViewer/CMakeFiles/ccViewer.dir/ccviewer.cpp.o
[ 97%] Building CXX object ccViewer/CMakeFiles/ccViewer.dir/main.cpp.o
[ 98%] Building CXX object ccViewer/CMakeFiles/ccViewer.dir/__/qCC/ccOverlayDialog.cpp.o
[ 98%] Building CXX object ccViewer/CMakeFiles/ccViewer.dir/__/qCC/ccCameraParamEditDlg.cpp.o
[ 98%] Building CXX object ccViewer/CMakeFiles/ccViewer.dir/__/qCC/ccDisplayOptionsDlg.cpp.o
[ 99%] Building CXX object ccViewer/CMakeFiles/ccViewer.dir/__/qCC/ccMouse3DContextMenu.cpp.o
[ 99%] Building CXX object ccViewer/CMakeFiles/ccViewer.dir/moc_ccviewer.cxx.o
[ 99%] Building CXX object ccViewer/CMakeFiles/ccViewer.dir/__/qCC/moc_ccOverlayDialog.cxx.o
[ 99%] Building CXX object ccViewer/CMakeFiles/ccViewer.dir/__/qCC/moc_ccCameraParamEditDlg.cxx.o
[100%] Building CXX object ccViewer/CMakeFiles/ccViewer.dir/__/qCC/moc_ccDisplayOptionsDlg.cxx.o
[100%] Building CXX object ccViewer/CMakeFiles/ccViewer.dir/__/qCC/moc_ccMouse3DContextMenu.cxx.o
[100%] Building CXX object ccViewer/CMakeFiles/ccViewer.dir/qrc_icones.cxx.o
Linking CXX executable ccViewer
[100%] Built target ccViewer
Re: Problem building plugins
Indeed, you are missing something ;)
When the message "Auto-adding ..." appears it only means that CMake is parsing the corresponding plugin script. You have to enable the INSTALL_XXX_PLUGIN option for each plugin you actually want to compile.
Warning: some plugins have additional dependencies. See http://www.cloudcompare.org/doc/wiki/in ... tion_CMake.
jonathanbyrn
Thank you so much for your help, I am very new to cmake. I found the relevant flag in cmakeCache.txt and it built successfully. Thanks again!
